Is there a "Red Baron" near you?
That's who I use and 9/10 times 2 days max if i get the order in before mi-day.
I now get a discount from them as my orders are frequent! Longest I have waited on anything was a Suzuki fuel tap from an old GS and that was nearly 2 months as there was no factory stock - was certainly bright shiny new when I got it.
Red Baron also do a great deal on buying Motul oil, You pay for 45L and get it half price - then it's just a case of popping in and getting your oil done when you like, no booking in just show up and give them the keys
900 Yen for changing and 1,575 with filter.
If you get your tyres from them they will fill with N2 and again anytime you want your pressure checked pop in and it's done FOC.
The shop beside me is the best franchised shop I have seen anywhere, I've sat and watched the mechanics working on bikes many times and no corners are cut - in fact they do a lot of small stuff that goes un noticed but makes a huge difference. I have no worries when they are working on my bike.
I set up my bike after fitting new carbs on and took it in to have them do it and they couldn't improve over what I had done already. So after 90mins (with a Dyno run) work they didn't charge me
I would hope all there branches are run on the same principle.
Later....
