you bend it you mend it!!
looking through some old pics tonight and came across these...
after a bit of hammering a soldering we got it to look like this ..........
hciR
Post by hciR »
Bloody hell did that in proper, at least you know the welding's good as it cracked the frame to the side of it!
The Pole
Post by The Pole »
The metal would crack to the side of the weld as the weld material is stronger than the original in most cases. cracks follow the line of least resistance. that one is right on the edge of the 'heat affected zone' which is always the weakest point, where the original material has been heated enough to change its mechanical properties.
how did you manage to bend that then?
When one lives in a world full of madmen, one should train as a maniac.
:lol:
April fools was 21 days ago Baz. Who's old bike is that that got bent up?
its the one rob636 bought to rebuild before he bought yours.
