Apparently the noise from the engine is the piston hitting the top of the engine. Can anyone relate to this as its doing my head in trying to raise the cash to buy new engine and if this bloke is wrong I'm gonna have to take it out on him :smt013
New Engine Perhaps
- insurerman
New Engine Perhaps
Hi guys its me again with the engine rattle. Just been told by an apparent reliable source that my big ends have gone on my zxr!
- BigNinjaDave
- My Bike: ZXR636, ZXR400
Short of being a master mechanic there are only 2 ways to find out if your engine is fooked:
1. Bits of valve are being fired out of the exhaust / sticking through the side of the engine.
2. You / he / someone, opens her up and sees what is what.
If its a H model or early L I'll take some of the sting out of a new engine by buying the cams off you
- insurerman
Its a 1994. It sounds like a tapet on a car. As you rev the bike the noise gets louder but on tick over, it isn't there. Gonna take the engine out tonight and have a proper look, Jmez has got an engine for sale so if I get it out tonight ill let u know my findings in the morning or later on tonight.
- insurerman
- BigNinjaDave
- diesel
- My Bike: Zx7r
- insurerman
Hi guys! Fresh from the garage and p***ed off a bit! Managed to get the rocker off with the lump still in the bike. Couldn't take lump out in the end as the bolts were so tight to undo, ive snapped my only socket. Out to get another tomorrow. Anyway couldn't find anything wrong or any signs of damage or pitting on the cams, not that you can see a lot if im honest. :smt013
i'm presuming you've undone the nuts off the engine mount bolts first and not trying to undo the bolts on their own?insurerman wrote: Couldn't take lump out in the end as the bolts were so tight to undo, ive snapped my only socket.
- insurerman
No I was undoing the nuts on the engine mounts. I managed to get one undone with a spanner underneath the fuel pump. Thing is ive had the bike for about 4 months now, and it was all taxed and mot'd and apparently recently serviced so I haven't really touched her. Now it looks like it hasn't been touched for ages. Nevermind, u learn by your mistakes i suppose.
Bit odd that it only does it when you rev it up. If its the cam chain im pretty sure it'll do it on tickover but quietens when you rev. Last time i heard an engine sound like that one of the piston rings had gone. You might want to check the valve clearances first before you take anything more apart, you nver know it could just be that.
Caz
- My Bike: GSX-R600 K4
Just had a cam belt incdent on my other halfs renault. very noisey at idle, but when you take it up through the rev range it quietens down.
When the covers were off and teh engine running - there was 1" play in each direction
albeit this was a cam belt not a chain
is there any loss of power?
blue smoke coming from teh exhaust?
and when did you last check your valve clearances?
what does the noise sound like? is it a quietish rattle? or more of a banging sound?
if you want to try and identify the problem without opening the engine up, you could always get an oil analysis done. the metal deposits in the oil will give you a good indication of what is wrong with your engine. It does help if the oil has been in for a while!
/Caz
/Caz
GSX-R600 K4
ZXR400 H2
Commuter: Gilera Runner 180SP
ZXR400 H2
- insurerman
No, it sounds like a tapping noise from the top part of engine. Only had bike 4 months so ive neva checked valve clearances. No blue smoke, its actually whiteish so that seems normal. I can recall that when i first heard the noise i was only a mile or so from my destination so i took it steady. When i started it up again 8 hrs later it didnt do it until a couple of miles up the road
. All in all id say the bike has probabgly done about 10 steady miles since the noise appeared. There is no play in the cam chain and the tensioner seemed fine when i checked that the other day. When we diagnose the problem, i think ill arrange for everyone to come round mine and we'll have a party
. Taking engine out tonight when i get home from work
