hello, i need some help lads i was riding home from work and i was on this long road and i decided to give it some any way it was hitting about 10-12,000 revs in 3rd gear than some funny sound came and the bike lost power.
it sounded like a differnt bike like a v-twin or somthink. I thijnk that one of the pistons in the cylinders is fecked can anyone shed some light on what the problem could be.
many thanks. josh
						help urgent about my engine
Dropped valve ?
Broken cam chain ?
Holed piston ?
Small end problem ?
Big end problem ?
Throwen rod ?
Broken rod ?
Broken camchain tensioner ?
Broken camchain guide ?
Any of the above in any combination or maybe even something else I can't think of off the top of my head
Take the airbox and exhaust off and shine a torch up in there you should see the valves............if they are still there.
There might even be a few bits of valve in the airbox/exhaust.
If it has broken something you looking at a compete rebuild or a new engine
						Broken cam chain ?
Holed piston ?
Small end problem ?
Big end problem ?
Throwen rod ?
Broken rod ?
could even be coils/leads or plugs breaking down??
