Now being winter n dark, iv noticed occasionaly that wen im waiting at lights/junctions it will die!!
Engine Cutting Out coz of Lights!
- SplaTZXR400
 - My Bike: ZXR400
Ok, well iv had this problem before, n i got it sorted, when the engine was idling happily if i turned on the main lights or indi's, not every time but most times the engine would eventally die. The reg/rec, n alternator have bin checked. I fixed it last time it was 1 bulb was incorrectly housed. So i adjusted n never had a problem.
  being indi's n lights im sure its the earth. Anyway a question i have is wot would happen if i insulated the bulb from the housing with electrical tape so they were not touching attal?? has any1 else had a similar problem with a soloution?
- SplaTZXR400
 - My Bike: ZXR400
the battery was new bout a month ago, never had a problem with the battery. but if  i pull the lights bulbs out the housing n turn them on with indi's, idle speed dont seem to change, only when they are in the housing, n i think is the right hand bulb thats the culprit. so it must be leaking a current somehow that kills the engine. stumped
i had these problems mate, it was the earth strap from the battery to the frame had corroded.
						- SplaTZXR400
 - My Bike: ZXR400
ok kl, cheers il give that a try. il did also wonder if it could have bin the altenator. like drawing too much current can cause more resistance on the crank, but  im notsure if it makes enough difference. i di also notice 2day that the 3 altenator leads are in a very bad state. rusted, corroded , fused or melted or something
  so il will clean everythin, thanks for the direction tho
						- SplaTZXR400
 - My Bike: ZXR400
the plot thickens...last night n th day before it was fine, no runnig problems attal! it rained alst night n this morning when i was in traffic, had my lights on, every time  i went 2 idle the engine died, was so annoying :smt013 eventually  i just unplugged the lights n didn't use them.  managed to arrive alright afterthat, just about.
i would definitely say there is either a bad earth somewhere or your battery is shorting.
						- SplaTZXR400
 - My Bike: ZXR400
well i think at some point soon, il take the tank off again n chek all the wires underneath. n i wan2 go throught the loom n cheack thoroughly, where everything goes. at least  i can rule it out if that dont work n assume its a component. i stil cant understand it tho, i tried 3 diffrent batteries 2day. cleaned the contacts. the engine still randomly splutters to a stop.
just a thought mate there is a yellow or green connector on the left hand side by the battery, this has been prone to corrosion and causing problems in the past, might be worth looking at.
						- SplaTZXR400
 - My Bike: ZXR400
oops i meant right hand side! i forget you know, its my age!
						- SplaTZXR400
 - My Bike: ZXR400
haha, no worries
 . well i went n bought some new indicators 2day, came back home, spent ages getting the old seized ones off. but when i did all this water poured out of it
  so..im wondering if this was the problem. the seals on the stems were broken n the lense was 2. i haven't tested it properly, like on the road. i started it, it idled at 1000 fine, i put all the lights on n indicators n idle was pretty consistant, i left it for bout 5 10 mins switching the lights on, off, on, off, on, left right, left, right, brake on, brake off etc. will hopefully find out soon if this was the cause. fingers crossed
						- SplaTZXR400
 - My Bike: ZXR400
does any1 no bout handmeters? i checked i think the resistance between the engine and battety with a handmeter on the ohms settings n the dial on '200', almost straight at the bottom on most.
anyway wen the engine is tickin over or off it reads bout 1.2 - 0.8 which seems normal on any wire or metal. but wen my lights are on or indis goin it jumps up n down to as far as 80.0 /20.0 / 15.0 etc jumps up all over the place but peaks round 85.0, is this normal? i tested my mates bike the same way n wen he used his lights n engine on it was a constant reading around 1.2/ 1.4 wot does this mean ??? a short or something???
- SplaTZXR400
 - My Bike: ZXR400
