636 front end
Banshee
636 front end
has anyone fitted a 636 front end to a zxr400?
what do you mean by front end?? forks and yokes or just plastics?
ZX-6RR (636) USD's
My 636 USD's arrived yesterday
and the Gold is a near match for the reserviour bottles on my rear Ohlins
They are off an '05 machine and are in perfect condition bar a few marks on the tubes. I tried fitting them into my H model bottom clamp but no joy
Bottom clamp is 50mm and 636 fork tube is 51mm so some slight machining will be required to get it to fit
my top yolk fits a treat as the 636 tube reduces down to 49mm.
I will also need inserts made for the spindle clamps as the 636 uses a hollow 25mm job this will save the expence of a ZX-6 wheel and matching rear.
Any of the Tokico Radial calipers should do but I think I will hold off and get Brembos.
So if the L model forks were beefed up too 51mm you'll be good to go - just remember to measure from your bottom clamp to the centre of the axle pin (unloaded) to get the same ride height, as the 636 forks use less stanchion travel than the ZXR ones.
Steering Damper
I have a NHK steering damper kit for fitting onto the ZXR USD's that's sitting on my shelf waiting for it's turn to be cleaned up.
I noticed today another one with a 51mm ring clamp for the fork tube and that it is advertised for a SP model. So I got my one off the shelf and tried it for a fit on the 636 USD's - no joy.
So I think it is safe to assume that from 1991 the fork tubes on the ZXR are now 51mm therefore 636 tubes will fit the bottom yolk OK
You just need to decide on a ZX6 wheel or inserts to fit the ZXR back on.
