Do The Shimmy ?? !! ??
the_avenging_bucket
Post by the_avenging_bucket »
:smt017
i am thinking of checking valve clearances myself...
i gather from the parts diagrams that shims go from 2.55mm to 3.5mm in 0.05mm increments...
has anyone done their shims? are shims 9.48 or 13mm diameter or what? anyone kno where to buy?
also a step by step description of shim removal and fitting would be appreciated...
'the people who are crazy enough to think
they can change the world, are the ones who do'
Bikerz
Post by Bikerz »
I had mine done by the tunners mate, was only 250 quid for a full tune up, carbs balenced and re jeted and valve clearences adjusted and valve shims done (needed 6) and cam chain. Not bad for 250 quid cash :smt003
does it not tell you in the manual how to do the shims?
sloweracing
Post by sloweracing »
Its quite a job mate pay some one else would be my top tip
Its not to bad checking the shims but can be a bugger if need changing espically if you leave the engine in on the L model dont drop any down the engine :smt002
Sloweracing Powered by
http://www.hodsonengineering.co.uk
the_avenging_bucket
unfortunately seems the manual doesn't go into to much detail...
have had some bad experiences with mechanics here in Pretoria, and most of the good shops don't do grey bikes- and i'm a firm believer in 'if u wan somethin done right do it urself'
so i'm gonaa take teh bike apart day after tomorrow, see whats going on.
thanks for the input, chrs
Ive got a book that tels you how to do shims, i would scan it in for you but im still at uni at the moment and everything has gone home. Im back home this weekend if you still need it i will scan it in for you.
Its not that hard from what i read, but i think you will need a special tool to compress the valve spring so you can take the shim out. Youll also need a magnetic tip to lift the shim out.
Delen
Re: Do The Shimmy ?? !! ??
Post by Delen »
If you could post a scan it would be great. My last race the bike started ticking as hell, thinking its the valves since its about time to do them anyway, but no clue on how to do it. :smt017
You Don't fail until you give up!
Delen
Re:
Post by Delen »
RedexRobB wrote:Ive got a book that tels you how to do shims, i would scan it in for you but im still at uni at the moment and everything has gone home. Im back home this weekend if you still need it i will scan it in for you.
read above :smt003
tobomoto
My Bike: zxr400l4 zx7r
Post by tobomoto »
off topic a bit but from the title i thought it was some sort of dance? :smt017 i was expecting a youtube moment!!
anything is possible with enough time and money. and an open mind...
