Engines
waddo
Engines
Post by waddo »
Hi
Does the H and L model use the same engine? Want to fit a good H into an L frame and wondered if anyone had done the same.
speak to sloweracing i think he's done it the otherway round tho.
richie400ss
Post by richie400ss »
yes you can do this.
remember that you will need airbox, cdi, wiring, exhaust etc from the L model.
in short, as long as it is just the engine itself you are fitting from an h model it's no problem
sloweracing
Post by sloweracing »
Sorry bit late now just got back from france racing :smt004
Yes the standard H model and L model will swap over no problems no nothing just straight in
The S.P. is the only problem with a couple of items different but you can email if need to know
Yes just bolt in the engine and all your wiring will fire up no problems with all the L model exhaust and electrics all the same
Any more help give me till tuesday sorry tied and havent unloaded yet
Hope that helps till then
