Very informative threads, thanks a lot. I'll feel much more confident going at it now with all this information at hand, read mori's guide 3 times now and it all makes perfect sense
I couldn't do it without you guys, Keep up the good work
Valve clearance check and shim swap discussion thread
Vaughn
- My Bike: Zxr400
GeorgeMoroz
- My Bike: ZXR 400 L3
Re: Valve clearance check and shim swap discussion thread
understand its been a while but just a quick question, some, not all of my clearences were large on inlet and exhaust however im not running an oil cooler, the largest on inlet and exhaust was about 0.23. would you accept this as a tolerable clearence if theres no oil cooler?
btw the bike still runs cool according the the water temp guage, got a nice strip of tape on the rad.
thanks!
thanks!
.23 is a too large for an inlet you will need a shim thats 0.05mm bigger than whats in there, also ive always tried to get my valves to be approximately the same value across all the inlets, or across all the exhausts
