weird zxr h?
richyrd5
- My Bike: 400h
weird zxr h?
i seem to have a strange zxr,,its suppossed to be a H model(bodywork is for sure)but the coolent bottle is under the tank?..is it meant to go there??it has(i think)a L model camchain tensioner..not the central bolt type as on other H models..later L type calipers(as i bought in error a set of pads for a L,but when they came they fitted !!).ive got a set of wheels coming soon so wondering now are they H or L wheels,,i know the cush drive is larger on the H rear wheel.is the front different diameter spindles?will they fit the H forks(if they are H forks!!)
Re: weird zxr h?
the coolant expansion bottle is under the tank for H model bikes, L model bikes have it under the passenger seat.
if you have the screw and o ring (listed here as 130 and 670) (http://www.cmsnl.com/kawasaki-1990-h2-z ... ml#results) then its a H model tensioner.
you can check the engine number and see if it matches the frame, or a H/L year bike.
i think if you have L brakes you will have L wheels, the front disk diameter is 310 on the L and 300 on the H.
richyrd5
- My Bike: 400h
Re: weird zxr h?
A mine of info as usual...cheers banner...so I could have L wheels..hmm..will have to check this out...
.so if L model calipers are fitted do you have to use L discs as well??.
ManxMan
- My Bike: ZXR400
Re: weird zxr h?
banner001 wrote:the coolant expansion bottle is under the tank for H model bikes, L model bikes have it under the passenger seat.
Really
I thought I saw mine down beside the clutch cover with the lid stick up from the fairing
Re: weird zxr h?
yep thats the one, sorry i went into fzr1000 exup mode for a second
yes RHS behind the panel, secured with 2 long bolts...i never forget a bolt.
richyrd5
- My Bike: 400h
Re: weird zxr h?
That's why I mentioned it as in the camchain fitting pics I saw the reservoir by clutch cover...so h models are under tank....my discs are 300mm btw but have later calipers fitted...
Re: weird zxr h?
post some pics
