Restricted or go for it!!!
I think the only detrimental thing would be makig it run lean, if you make those inlets smaller with washers surely its not getting the right amount of fuel so could end up with what happened to zxr400er. But ive never heard of that happening so probably isnt true. So in what way would it damage the bike? I dont think its true myself.
Ive never really heard that restricting them is bad, 748's are a bit pants on accleration anyway, two people i know have a hard time wheelieing them off the throttle in first :S
- deviant
- My Bike: ZXR400 L3
Carburettors are magical devices that put the right amount of fuel into the air coming through them.
If you don't open the throttle all the way, less air will go through the carbs and so less fuel will be sucked into it, and the mixture stays about the same.
If you put a washer between the carb and the engine, less air will go through the carbs and so I imagine it will behave exactly as if you are not opening the throttle all the way.
If it did alter the fuelling, I imagine it would tend towards rich anyway, as if you were riding with the choke on (again, the choke restricts the amount of air going through the carbs).
I wait to be corrected...
D
ps: what sort of muppet restricts a 748?
D
tbone2889
- MveZ
Taking the kit off
Yesterday I took the restrictor kit off of my L2, it wasn't that easy, and it took a couple of attempts to get the thing going properly!
But now, omg, that extra power is absolutely amazing, its like stepping onto a brand new bike, i smiled so much!
Kinda developed a couple of problems now (my fault for being a bit of a rubbish mechanic)
1. the idle rev adjuster thingie is not working!
2. The tank does not seem to have fit back in properly
I also found out that my fuel tap does not work in the off position, oh well, i guess i didnt loose that much fuel.
Only 2 months to go until i was supposed to take it off......
zxaaahhhhh
Mat_2001mat
- deviant
bought mine just after i was derestricted, so I haven't really got any experience, but i imagine (based on my fiancee's restricted gpz500) it will still just about drag itself up to a ton, will still outdrag pretty much any car, and of course it will handle exactly the same as a full power bike.
CarneyUK
After having the restrictors taken out I would say it made a hell of a difference, especially in the top of the rev range. When I first got the bike with the restrictors in it was still bloody quick and as Deviant said would still beat most cars off the lights!!
The main thing is it will stop you losing your licence in the first year coz as soon as mine were out I was hitting the redline every chance I got.....Bloody Awesome
As you said it's only for the summer so will give you a chance to get used to the bike.
If you wanna see the difference then check out Video 4 on my website.
Mat_2001mat
Thanks for the info guys.
Nice vid Carney. Looked like you got it up to about 70 de-restricted. Made a huge difference when it was taken off. Looks like fun
. I like the pic of the bike in the house, was it too heavy to take it into the bedroom?
How much did you get your bikes for? Do you think I could get a reliable ZXR400 for 1k - 1.5k ?
I have 2k in the kitty for my bike and gear so the budget is rather limited.
you should be able to get yourself a nice L model for that money!
CarneyUK
maz66
I'm in the same position, never ridden bikes before and restricted to 33bhp for 2 years. However i havent bothered getting my zxr restricted, just passed my test 2 weeks ago but its been amazing although it is limited to 10k revs at the mo i have found the power to be controllable. I bought my l9 for £1700 and spent a further £150 on bargains from ebay, its all newish or new alpinestars stuff. So it can be done on a budget but you do have to wait for the bargains. Just go for it
Mat_2001mat
I'm not sure about the legislation but if I got caught without the restriction and lost both my car and bike license then id be pretty screwed as i live in the country. It's just not worth the risk for a 150 quid job.
Il keep my eye on E-bay as it seems to have the best deals.
Thanks for all the advice guys and happy riding and hopefully il be posting back when I finally get my zxr!
Take care
Mat
Take care
Mat
