wheels spindle diameter ?
Tricky
My Bike: ZXR400
Post by Tricky »
anyone know the outside diameter of the wheel spindles on an H and L ?
cheers.
Dominik
My Bike: Zxr 400 L3
Re: wheels spindle diameter ?
Post by Dominik »
All L-Models have 20mm diameter front and rear, H should be the same but I don´t know for sure.
Most Zx6r s have 25mm.
Zxr 400 SL - 130kg
Tricky
My Bike: ZXR400
Post by Tricky »
thanks for the reply Dom, but H are different size from L.
H2 is the same as L, H1 is smaller..I'll try to remember to check later for you.
Ewetea
My Bike: ZXR400L5
Post by Ewetea »
Rear spindle on H1 is 17mm diameter. Front spindle on H1 is 20mm, but has larger diameter fittings at each end of 27mm diameter, compared with 25mm dia for the L1. These fittings engage with the holes in the lower fork legs and have an internal hexagon for tightening. Thus an H1 spindle cannot be used on L1 forks, nor an L1 spindle on H1 forks.
Tricky
My Bike: ZXR400
Post by Tricky »
thats fantastic, thank you very much. :smt023
