ZXR Bogging down
zxr500man
ZXR Bogging down
Hi Everyone,
I just finished rebuilding my carbs. New everything, jets, seals, orings, etc..
I also got my valve clearences done and camchain was fine.
Its a zxr 400 h1.
105 mains, new pilot jets. Main air correctors blocked. 30mm velocity stacks
I just done the float height also.
New inlet rubbers. No air leaks...
Full ti beet down pipes and open can.
Race air box.
It runs fine to 6k revs, it bogs down and bangs and misses to 8k and wont pass that....
Its got a new battery also, new oil, etc...
I belive the problem is with the carbs, but I just cant sort it out.
I had the pilot screws at every possible turn, changed the float height several times..
It will rev to 12k when in neutral but will not rev out when driving....
If anyone can give me some advice, I would really appreciate it.
Thanks for reading.
Its a zxr 400 h1.
Race air box.
Thanks for reading.
zxr500man
Re: ZXR Bogging down
When sitting in neutral and looking down into the carbs, when reving it out, fuel sprays up from each carb in a mist....from around 6k - 12k...
This lead me to think it was running rich.. but I aint sure either..
zxr500man
Does anyone respond to anything on this site anymore?
- Miles
- My Bike: ZXR 400 L3
Maybe nobody knows the answer
zxr500man
That must be it!
- Miles
Nothing gets past you
The 12k limit sounds suspiciously like the limiter on imports. Which cdi are you running?
- Dominik
- My Bike: Zxr 400 L3
What makes the difference between driving and neutral is how the air enters the airbox. I hardly believe that this is you problem but maybe the race airbox isn´t installed properly so that it doesn´t get the air right.
The zxr spits fuel out of the carbs. That is quite normal and not due to running rich..
Zxr 400 SL - 130kg
zxr500man
Thanks for the replys...
I will check the cdi to see what one it is.
When I was testing it, I was not fitting the airbox, also it has a fuel cell, so carbs were exposed...
I will fit the airbox and test it.
Also the 12k issue is a limiter.
At the moment Im just trying to get it going properly up to 12k..
zxr500man
The cdi has the letter z on it..
zxr500man
Hi, just want to say thanks for the advice.
I stuck on the airbox and its running like a dream.
Very smooth!!
Id say it has never ran as well!!
Just need to get it derestricted now..
Very smooth!!
