head gasket
courty
head gasket
my zxr has been off the road for a year so had the carbs cleaned and the brakes sorted and started using it to go to work i have noticed that the oil level viewing glass has all gone white and when i took off the oil cap there was lots of white foam on it is this allmost certainly head gasket failure the bike seems to be running not to bad cheers courty
if its been stood soo long and especially in this weather it is more than likely damp and condensation causing the mayonnaise get it warm and then have a look it should disappear, if you check under the rad cap there will be fine bubbles if your head gasket has gone, you will also notice poor running and overheating.
Guest
is it stuck to the eye glass? you might need to do an oil change then use engine flush before you change the oil.
- diesel
- My Bike: Zx7r
Bikerz
mates does this just rag in sensless for 30 min and it goes mate
