Right been really lazy with taking pictures but managed to make some good progress. Engine is in, all wired up, cooling system is in and blead, as are the brakes. Got to. Point where I could start it and nothing... Turned over like a trooper however no spark and began doubting if the stick coils were working. So I banged a brand new Bosch battery in as the other had sat in the garage over winter and did not want to hold charge and also x4 new spark plugs in and vroom started first time. Revs ran round to 8k sat there then dropped to 2.5k where it either revved or cut out upon throttle. Sounds like an air leak so took the carbs and inlet rubbers off, sealed the rubbers to the head and put the carbs back, also made a new silicone gasket that sits inthe well between the carbs and air box. Currently waiting for this to set before I can bolts her back together for run no.2. Will nee the carbs balancing as I have no gauges and will probably have a power run on the dyne at the same time.
Here's how she stands now, just lots of smaller jobs left to do like sort out the chain slack, sort carbs, indicators etc.... But they all add up
Managed to get it nearly finished. Should be going in for the MOT this week. Got it running with no major problems, just a few headscratchers..
Just need to clean the side fairings up best I can, although theyre not in great shape but id rather get the bike on the road and get them sorted over next winter.
More pics to follow
Im glad i kept the original colours too, mainly due to a lack of funds, but may get them resprayed the original colours over winter. Passed her MOT today, just a few bits left to fettle then we are all good.
Enjoyed reading/seeing this one resurrected. You mentioned earlier that you were planning to make up some blanking plates for the oil cooler and remove it, but looks like it's reappeared in the later pics. Did it clean up ok in the end or is the cooler an absolute necessity? Bike looking really good - have fun riding.
The original plan was to remove it but I managed to clean the original one up. Since riding the bike it sprung a small leak in the cooler - re-enforcing my views to remove it in the first place however I have just sourced a good condition one second hand. After reading through pages and pages of differing views on the web I decided to stick with the oil cooler as although the bike is for fast road use My journeys will often encounter slow/standing traffic. I have a spare sump pan and am thinking of creating the blanking plate for it just as something to do... thanks for the comments
