can a front rim be repaired
Deano2485
- My Bike: zxr 400 l4
Hi I have got a front tyre that has a slow flat after a track low side on closer inspection I can see to areas on the sealing edge of the front rim where it runs out away from the tyre (don't know if this was like this before and the paint hasn't been damaged) can this be repaired or could the slow be caused by the bead being pushed in and broken in the crash
- CaNsA
- My Bike: ZX6R F1
Re: can a front rim be repaired
Pics needed,
ross46
- Restricted
- My Bike: zxr 400 l6
Get a spray bottle with water and fairy liquid in it, pump up the tyre and spray it, you'll see it bubble at the site of the air escaping
Deano2485
To be honest you would see sod all in the pictures I only noticed when looking from the caliper and spinning the wheel. Ok I will give that a go
Vaughn
- My Bike: Zxr400
Got 2 front wheels for sale if you need, just let me know
ross46
- Restricted
Is it letting air out?
- CaNsA
- My Bike: ZX6R F1
I had a slow puncture a while back.
Turned out that there was some corrosion on the rim lip where the rubber sits.
A wire brush soon sorted it out.
