Swap Out
Striton87
- My Bike: 1990 kawasaki zxr 400
Swap Out
I have a 1990 kawasaki zxr400 H1. im assuming the rear tires are default because the size is 150/50 17R. My question is can i fit a 170/60 R17 on my bike? and if so i should be able to keep the same rim right?
Re: Swap Out
standard H2 and L model rear tyres are 160x60...so a 160x60 should go on fine, a 170x60 would add another ~1 - 1.5cm to the diameter of your rear, so check it will take it.Striton87 wrote:I have a 1990 kawasaki zxr400 H1. im assuming the rear tires are default because the size is 150/50 17R. My question is can i fit a 170/60 R17 on my bike? and if so i should be able to keep the same rim right?
although why you would want it is another matter...
ross46
- Restricted
- My Bike: zxr 400 l6
Re: Swap Out
Do you mean diameter or width? I know the second number isn't height its a ratio but just to make sure for the OP
noodleface
Re: Swap Out
i think he means circumference
-nf
-nf
ross46
- Restricted
Re: Swap Out
ok, in which case its just simply rearranging pi*d for d
cloud9
- My Bike: zxr400 L4
Re: Swap Out
my L4 has a zxr750 rear rim fitted and runs a 190 x 55 just like any modern 600. gives more choice of tyres.
ross46
- Restricted
Re: Swap Out
Zxr750 uses a 180 rear unless im mistaken? And what year/model zxr750, and what are the pro/cons on using 180 vs 160 rear?
stuzx4r
- My Bike: zxr400sp race bike
Re: Swap Out
hi, I am also running a zxr750 wheel with a 180 tyre in one of my race bikes.
The wheel is from a 1991 zxr 750 J model.
Hope this helps.
Hope this helps.
alanh
- My Bike: zxr400 L racebike/R1
Re: Swap Out
Does this slot straight in Stu? Wouldn't mind running a 180 rear wet.
zxr400L Race Bikes Competing in EDIASIA F400 and thunderbikes with BMCRC in 2016 and an RD125LC MK1 restoration project
stuzx4r
Re: Swap Out
unfortunately it requires new spacers to be made, i can send you details on the spacers if required.
I have over the last few weeks fitted a zx6r G/J model rear wheel, an easier conversion and still runs the 400 disc.
alanh
Re: Swap Out
just a case of new spacers for the 6 g/j wheel? A1p 636 will be the same too, its just a bored out j modelstuzx4r wrote:unfortunately it requires new spacers to be made, i can send you details on the spacers if required.
stuzx4r
Re: Swap Out
wheel bearings changed to 6304 and the spacer that would have been on the right in between the wheel and the brake hanger not used. ZXR400 brake hanger, cush drive,disc and caliper used.
cosher
Re: Swap Out
very helpfull think of doing this is that all that is needed thank you
