So the mounting plate for my end can has been bent and is causing the can to sit at a strange angle.
Anyone got experience with bending these back?
I'm worried it'll just snap.
I'll get some snaps in the morning.
Bent mounting plate
- CaNsA
- My Bike: ZX6R F1
Re: Bent mounting plate
Stick it in a vice, use the vice to straighten it. No other tools needed.
If it goes fuxord, get a replacement from BikeBunker on here.
viewtopic.php?f=178&t=14617
The guy has sex with chickens on a daily basis but he he is reliable.
Might want to heat it first before bending as it will probably snap!
Columbo
- My Bike: ZXR 400 L9
Cheers for the heads up!
I've got a butane torch, a bench vice and numerous hammers.
Reckon that'll do it?
- CaNsA
- My Bike: ZX6R F1
dont use a hammer.
open the vice enough for the bent section to fit in.
heat the mounting plate
place in vice legnthways across the vice
close vice
let the vice do the work.
close vice
Columbo
The plate is straight but it is bent in relation to the pipes. I should have made that clear.
Pipes are straight but can sits an an angle with a slight rotation.
- CaNsA
- My Bike: ZX6R F1
Sucks to be you then
