fuel pump goes, but not the starter motor
- My Bike: zxr 400 L8
iv put the loom back into my bike, I got it all conected up and then tryed to turn the engine over from the starter button. the clock lights and fuel pump started to work but the motor did not turn the engine over. iv not had much to do with electrics so if any one has any ideas it would be a great help. Thanks
- CaNsA
- My Bike: ZX6R F1
Re: fuel pump goes, but not the starter motor
Did the carbs come off?
How long did you try it for?
Fuel tap turned on?
enough fuel in the tank?
Fuel tap turned on?
as cansa is alluding to, it can take 20-30 seconds of cranking to get the bike started with no fuel in the carbs.
but his bikes not even turning is it?
whoops...sorry, read it wrong.
if you want to diagnose electrical faults you will need a multimeter, that way you can check if its a wiring fault, or a duff starter motor.
Yea the bikes not turning
but the other stuff works. its just not turning the starter motor on the button. I know the starter motor is ok because it turns the engine over if i short the solenoid. iv also changed the solenoid becasue i had this kind of problem before so impritty sure thats ok too. its got me very confused :smt013
blimey ...
sounds like the same problem i think skullie's having with his ..
there's a relay in the fusebox (called junction box in the manual) if this dies you get everything except activation of the starter motor off the button as the bike becomes paranoid and behaves as if its in gear with the stand down and you havent pulled the clutch in. afaik its not repairable.. but a new fuse (junction) box should sort it.
cheers zimm il look into getting one of those naw. I was starting to run out of things to check. Would i be able to use the fuse box from any of the zxr 400s ?
according to manual, L5 is different to L1-L4, dont know if that means L5-L9 are all the same? dont know about H models and you've not said what yours is...
ok iv put a whole new loom in and checked the voltage from the battery. iv also put a new switch gear on thinking that maybe this was the problem. Iv got the loom all connected up and its doing exactly the same thing as it did with the old loom in :/ im realy running out of ideas naw
- My Bike: zxr400
Is the starter relay clicking when you try to turn it over?
and did you change the junction box as suggested?callum@93 wrote:ok iv put a whole new loom in and checked the voltage from the battery. iv also put a new switch gear on thinking that maybe this was the problem. Iv got the loom all connected up and its doing exactly the same thing as it did with the old loom in :/ im realy running out of ideas naw
there are only a few things which connect to the starter motor...
yea, i replaced everything, i put a complete new loom in :/
have you taken a multimeter and checked all the connections coming from the battery for the ignition system?callum@93 wrote:yea, i replaced everything, i put a complete new loom in :/
will the bike bump start? have you considered that thestarter motor might be knackered...might be good to post a list of the things you have changed as opposed to saying "everything".
the loom, all relays, cdi, fuse box and switch gear from another zxr but the same problem as i had before is still there. so this makes me think maybe iv got somthing in the wrong place
