Bike will not start in the morning when it is cold
basie
My Bike: kawasaki ZXR 400
Post by basie »
What can be the problem and how can I fix it.
Re: Bike will not start in the morning when it is cold
Hi, welcome to the forum.
Have u tried the choke?
basie
Post by basie »
Choke tried at all positions and still do not start
does it turn over? attempt to fire? got fuel?
basie
Post by basie »
Turn over,spark,feul, everything ok. Bike will just not start.
how old are the plugs? battery giving a good voltage?
basie
Post by basie »
Battery brand new, Stator brand new, Regulator brand new.
I am going to change the plugs this afternoon and check what its does.
Also need to check carb settings as it was disturbed when my son cleaned the carbs. Possiable fault. What would be the best settings on carb and best way to set
basie
Post by basie »
Hi the problem was with the spark plugs. The previous owner has installed the wrong type of plug. The bike now start first time in the morning and runs perfectly.
Thanks for all your posts.
glad u sorted it, any problems with not starting i always change the plugs first :smt003
