This was how my bike looked when i got it in September 2011. It was making 73 bhp and when i took it to Thruxton with NG it developed a misfire, so after the race the complete rebuild would begin.......
Once everything was stripped the frame and swing arm was sent away to be lightened and once they were away i set about refreshing the forks, and as the rear shock was working fine at Thruxton so i decided just to clean it up...
After that the main focus was the engine, we decided to check the tolerances and when we checked the base gasket was still in and the cam timing was quite a way out....
so finally the frame and swing arm came back, along with other lightweight goodies...
So now i had everything back it didn't take too long to get everything back on and together...
I'd managed to acquire some flat slide carbs during the build as well as some SP cams for my spare motor....
and with the coils proving the main headache last time out i decided to try the coil conversion.
and then it was time to give it a quick go on the dyno to see if she would go or not and it turns out she definitely has a bit of poke!!!
The bike is still not complete, we need to tidy everything up, get the flatslides setup properly, get the freshly painted bodywork on & sticker'd up as well as my newly painted wheels....
as soon as i get more info and pics i'll be sure to post them up here...
Si #3
