Needle adjustment
Posted: Sat Jan 31, 2009 2:25 pm
by schumiruby
i had my 1995 model dynoed yesterday and was told it was running lean. asked about putting bigger Main Jets in and he told me that i could adjust my needles to achieve the same result. can anyone explain how this is done and if at all it would have the desired result. my bike is standard except for a K&N filter and a Carbon Can Co. end can!
Re: Needle adjustment
Posted: Sat Jan 31, 2009 3:37 pm
You can raise or lower the needle by changing the position of the circlip on it.
There are 5 maybe 6 grooves on the needle
Posted: Sat Jan 31, 2009 3:51 pm
by schumiruby
im running lean! do i raise the clip or lower it?
Posted: Sat Jan 31, 2009 9:06 pm
by mick41zxr
Raise them. Also can be done with washers.
Posted: Sun Feb 01, 2009 1:15 am
by jake
i dbe surprised if the needle needed richening? it would be a first for a zxr that ive heard of tbh.
sort the main jet out first, then come back to the needle.
Posted: Sun Feb 01, 2009 10:44 am
by schumiruby
thanks for your replys! i think ill go for 102.5 keihin jets then. how does that sound?
Posted: Sun Feb 01, 2009 12:11 pm
by jake
id give the carbs a good clean, get an airline thru the jets,etc.. carb cleaner. check the fuel filter too
what size is standard on a 95 L? import or uk? id go up maybee 1 or 2 on the mains from whatever is standard
Posted: Thu Feb 26, 2009 8:29 pm
by mark400
Surprised your Dyno guy didn't have jets, but I guess eventually they won't be needed at all....
There is little point playing with the jetting without being able to read the fuel/air ratio - I would either buy a large range of jets 4 x 100 / 102/105/107 and take them with you next time(expensive) or just go to a dyno that stocks jets.
