GP/reverse shift pattern
Posted: Sat Dec 06, 2008 9:43 pm
by The_Doctor
Ok, not sure if this is the right section to post this - its more modification than tuning.
Anyway, I was wondering if anyone on here has ever tried or managed to convert the standard shift pattern of their ZXR400 to GP/reverse shift? I tried searching but couldnt find anything. If so, how is it done on this bike?... i've read some bikes can be changed by just turning the gear linkage upsidedown (or something like that!), and other bikes require extra parts and spacers etc. I know a lot of people say dont bother, its only for racing blahblahblah.. but i just want to try it and see how it feels.
If anyone knows anything about this, i'd love to hear.
Cheers guys.
Re: GP/reverse shift pattern
Posted: Sat Dec 06, 2008 9:52 pm
It is as simple as rotating the gear shift 180 on the splined shaft, only thing is i dont know where thats puts the gear lever height. You can adjust it using the adjuster rod.
Try it and let us know how you get on.
Posted: Sat Dec 06, 2008 10:28 pm
by jake
aye, just turn it upside down, there should be plenty of adjustment still.
I still use road shift on the track so cant comment, but i can imagine it would be faster getting on the gas when your on its left ear, and also maybee easier to know which gear your in when you hammer down into a tight corner
Posted: Sat Dec 06, 2008 11:10 pm
tried it hated it went back to road styleeeeeeeeeeeeeee
Only found one corner where it causes me a problem being road styleee
Posted: Mon Dec 08, 2008 6:57 pm
by The_Doctor
Ok, cheers everyone. Will try it tomorrow when i get home and see how i get on - though i can imagine downshifting the wrong way in particular will take some getting used to...
Posted: Tue Dec 09, 2008 8:54 pm
by Ballsout Racing
I had to do it when I started racing my RS250, just kept getting my foot jammed under the lever, being a 2 stroke you to have the correct gear, probably would get away with a standard shift on a 4 stroke due to wider powwr band. I found it immediately so much easier. Quick downshifts are far less important than quick up shifts :smt003 :smt002
