REMOVAL OF THE GENERATOR = BHP
Posted: Sat Jan 09, 2010 7:40 pm
by Kirky Boy
Is there any truth that if i remove the generator i will gain more power, is this total loss set up? Not too sure. If there is a gain could someone please guide me on how to do this.
Cheers!
Re: REMOVAL OF THE GENERATOR = BHP
Posted: Sun Jan 10, 2010 1:46 am
by mark400
Takeoff the generator casing, remove the windings from inside. Pull off (with a puller) the rotor and starter gear. Block off the oil way used to lube the starter, and I think you need to put the bolt back in the end of the crank.
Posted: Sun Jan 10, 2010 10:56 am
by Kirky Boy
Thanks for your reply, that has cleared things up a bit. Will be doing this later this week.
Posted: Mon Jan 11, 2010 4:58 pm
by Fatspanner #44
If you want to keep the starter then you can just drill out the rivets and remove the magnet which is the heavy part. Highly recommended as it makes a massive difference in drive out of low speed corners.
Posted: Tue Jan 12, 2010 2:38 pm
by Deswilkie
Hey Colin, you can practice that on mine when I get the head back.
Posted: Wed Jan 13, 2010 10:28 am
by Fatspanner #44
I have one ready to go for you!!
