Page 2 of 4
Re: Kawasaki zx400
Posted: Sun Feb 20, 2011 2:11 am
by Mori Man
If you look at zimms photo you will see:
Swinger , wheel , disc , caliper , Forks , wheel , disks ,calipers and I would imagine the triples to mount the forks.
I like them - mini ZX10
Re: Kawasaki zx400
Posted: Fri Feb 25, 2011 10:28 pm
by skullie
lol am thinking of trying to put a single swing arm on it !!
cheers for the info Mori-Man
will look for zimms pic and check it out
Re: Kawasaki zx400
Posted: Wed Jun 29, 2011 1:43 pm
by gangster
can anybody help ive lost the keys to my kawasaki zx4
Re: Kawasaki zx400
Posted: Wed Jun 29, 2011 2:16 pm
Not sure how we can help other than finding the keys or suggesting u buy a new lock set....
Re: Kawasaki zx400
Posted: Wed Jun 29, 2011 2:28 pm
by gangster
are the keys not universal on the older models
i found a ignition set on ebay for £30 but i need keys for the pertrol cap and the seat lock
is there any way of getting to the battery with out the seat lock key??
thanks
Re: Kawasaki zx400
Posted: Wed Jun 29, 2011 2:31 pm
by Mori Man
Could get you a complete lock set - but your going to have to brutal to your existing locks ie* : 16mm drill to bore the cores out then replace with used kit
TOP TIP:
Go get your key cut as soon as you buy a bike and give to your gran/granpa - don't trust your parents
MM!
Re: Kawasaki zx400
Posted: Wed Jun 29, 2011 2:33 pm
by gangster
will other peoples keys not work on mine seat lock? fual lock?
Re: Kawasaki zx400
Posted: Wed Jun 29, 2011 2:37 pm
by Mori Man
Sometimes your lucky and seat lock will work with most keys - fuel cap your going to bend a key - ignition no freakin hope, HELLO !
Re: Kawasaki zx400
Posted: Sun Dec 04, 2011 7:50 pm
by dirtyrat
Hi,
mines an '88 zx4 G too !!! cheaper alternative, basically the same engine as a zxr, mines just had a complete engine rebuild, fitted a zxr race tail, had to add pieces of the original tail section with the old friend fibreglass for it to fit up to the tank though.
Shes guna be a streetfighter, dominator lamps e.t.c, resprayed her twice but planning a final paint job when shes on the road, which isnt long now.
Sadly I fell short of funds for the original plan which was to be able to add fairings/clip ons for track, jack up/add raask risers and gold renthals for streetfighter look and a lowering kit for a drag stance, though am happy with the look for now, I cut down the orignial lowers to make a one off belly pan, it looks great just gota pick up some straight brackets cause none of the mounts line up at all now!!
from how it looks to me most of the parts of a zxr should fit, from what is noticeable the frame is only different to the H model with the outside mould and the ZX frame looks more chunky adding to a better butch streetfighter look.
Only thing I cant find is a jack up kit, tried everywhere, I cross referenced the parts of the uni-trac and according to the kawasaki parts fiche the suspension/dog bones are the same as the 750 but I emailed a company who said the 750 jack up dog bones are straight :/
So if anyone knows where I can pick up a jack up kit please drop me a note !!!
Hope some of this helps.........
Re: Kawasaki zx400
Posted: Tue Dec 06, 2011 5:26 am
i'm liking the look of that, start a build thread and put some more pics up
Re: Kawasaki zx400
Posted: Sun Mar 11, 2012 10:59 am
by dirtyrat
Re: Kawasaki zx400
Posted: Sun Mar 11, 2012 11:02 am
by dirtyrat
another couple of pics........
Re: Kawasaki zx400
Posted: Sun Mar 11, 2012 4:01 pm
by dirtyrat
masterofinsanity wrote:i'm liking the look of that, start a build thread and put some more pics up
I'll sort one out for when shes on the road with maybe a list of parts wanted for completion, kinda busy right now (but gettin it built !!)
Re: Kawasaki zx400
Posted: Wed Mar 21, 2012 7:20 pm
by dirtyrat
Has anyone got a complete wiring diagram for this model, I have the zxr wiring diagram but on my loom there is a blue wire to eah side indicator on the front only, not the back, this is not on the zxr wiring diagram and I havnt got a clue what it is, my bke is nearly finished, just gota do the brakes, finish the wiring, bolt everything down, add fuel, turn over engine........PLEASE HELP
Re: Kawasaki zx400
Posted: Fri Apr 06, 2012 5:24 pm
by dirtyrat
dirtyrat wrote:Has anyone got a complete wiring diagram for this model, I have the zxr wiring diagram but on my loom there is a blue wire to eah side indicator on the front only, not the back, this is not on the zxr wiring diagram and I havnt got a clue what it is, my bke is nearly finished, just gota do the brakes, finish the wiring, bolt everything down, add fuel, turn over engine........PLEASE HELP
Oh it dont matter anyways, pretty much got it sorted now, only prob I have is the neutral light / no spark but its delayed again now as have had a redicision on the tail section, been butchering the subframe last 2 days, need to heat n bend it just right but else its lookin roughly like this.............
