Removing base gasket
Posted: Wed Jan 14, 2009 8:17 pm
by zxr4000
Hi all,
I've heared some racers have removed their base gasket and skimmed the cylinder head. My question is how the cylinder base is sealed without this base gasket?
Roy
Re: Removing base gasket
Posted: Wed Jan 14, 2009 9:35 pm
by lewisdale
sealant
Posted: Thu Jan 15, 2009 5:49 pm
good old hermatite i think does the trick
Posted: Thu Jan 15, 2009 7:27 pm
by noelb
As there are oil galleries thru the split I try to use some of the new fancy sealants, and very sparingly. The last one I did, I used kick-ass loctite (910 I think) and never had any bother but will be using Dirko this time - any decent motor factor should have it. I seems to be the modern car equivilent of yamabond. Thinking of it - yamabond would probably do the job as well!
Noel B.
Posted: Sun Jan 18, 2009 3:15 pm
by zxr4000
Thanks for the hints guys..
Posted: Mon Feb 02, 2009 10:25 pm
by zxr4000
Hi All,
I just heared that removeing the base gasket could damage the piston rings because the barrels are lowered and the rings touch the upper part of the barrel that hasn't been used (ran in) ever before. Sound plausible as my engine is from 1998 with appox 15000mi..
Anyone removed the gasket on a used engine or does it rquire the barrels to be honed on a used engine?
Roy
Posted: Mon Feb 02, 2009 10:37 pm
by lewisdale
good point mate but surely you should have youre barrels honed anyway if your removing the top end, even if the same piston and rings are going back, this is what ive always been told from a early age on car and bike engines, ideally i would replace the rings at the same time too
