Engine work
Posted: Sat Sep 06, 2008 2:37 pm
by Jerry
Hi has anyone had there head skimmed if so how much do they skim off the head also does anyone know the website or number for RMKD.
Re: Engine work
Posted: Sat Sep 06, 2008 3:14 pm
by zimm
tolerances vary so much that there isnt a set amount to take off the head, its all about getting the squish right.. and every tuner has their own method.
I bin the base gasket (.2mm) and take .25 mm off the head which works and isnt so extreme that things go pop... so far.
Roger (RMKD) has said in the past that he gets the head taken back till any more would be eating the valve seats (anything upto .75mm).. but he also machines the pistons and block, so this approach may not work in other circumstances. He doesnt have a website, but a search for RMKD on here should bring up a post with his number in, i'd feel funny about handing it out tbh.
Re: Engine work
Posted: Sat Feb 07, 2009 10:48 pm
by zxr4000
Zimm,
Did you do anything to the barrels after you got rid of the base gasket?
Roy
Re: Engine work
Posted: Sun Feb 08, 2009 9:49 am
by THE FLUTE
Barrels are normally just machined across the bottom liner to the opposing barrel to releive a bit a transfer pressure as I understand it But I stand to be corrected
