Help needed on sprocket setup
Posted: Thu Jul 03, 2014 8:38 pm
by p.lally
Hello, I am needing some advise on sprocket setup, I am currently building a bike which I intend to use on the track.
I am wanting it set up more for acceleration rather than top speed (but not that much it runs out of go)
Can anyone please advise on which setup to go for???
I'm thinking of 14/47
Re: Help needed on sprocket setup
Posted: Thu Jul 03, 2014 10:48 pm
by kawazonkey
What tracks are you racing on? Different set ups for different circuits!
Posted: Fri Jul 04, 2014 7:21 pm
by p.lally
kawazonkey wrote:What tracks are you racing on? Different set ups for different circuits!
Hi, hopefully first one on this bike at cadwell (next month), but then probably any of the ones up North, Anglesey, oulton park or donnington
Posted: Sat Jul 05, 2014 11:36 pm
by wes
I used 14-46 for Donny and Brands Indy
15-46 for faster tracks like Snetterton and Silverstone
Posted: Sat Jul 05, 2014 11:37 pm
by wes
Use search here to find other tracks and posts....
Posted: Sun Jul 13, 2014 8:53 am
by stuzx4r
hi, obviously the amount of tuning and more importantly how hard you ride will affect what your gearing you require, however for both Oulton and Cadwell I would suggest 14/48.
(I'm assuming your on a standard L gearbox)
Good luck and have fun.
Stuart.
Posted: Sun Jul 13, 2014 9:25 am
by p.lally
stuzx4r wrote:hi, obviously the amount of tuning and more importantly how hard you ride will affect what your gearing you require, however for both Oulton and Cadwell I would suggest 14/48.
Stuart.
Hi and thanks, I am looking to hit cadwell shortly and I have just bought a 14 and 47. My bike is a h2 model.
Peter
Posted: Wed Jul 16, 2014 9:00 am
by stuzx4r
Hi Peter, you will be in the correct area with 14/47, it will probably feel as though its to short as you bimble round for the first couple of laps, but once you have it opened up at reving to 15k it will be fine. H2 gearbox is very close to the common L box so you will be fine, its only the H1 that's shorter.
Have fun, Stuart.
Posted: Wed Jul 16, 2014 9:27 am
I like to have a selection of sprockets to choose from. I've got rears from 40 up to 50 and fronts from 13 to 16
After an initial estimate and lap or two I can then select the best set up from the options available.
What you're actually trying to do is get the gearing so that at the end of the longest straight the bike is 6th gear on your bikes red line and your just about to brake for the next corner. You can of course play with the gearing to suit a particular section but that will come at a cost elsewhere.................as ever there is a compromise to be had.
Wind speed and direction can be a factor too as can wet or dry track conditions
Posted: Fri Jul 18, 2014 1:40 pm
by 400y
Cargo - what gearing do you run at Armoy on the 400?
Posted: Fri Jul 18, 2014 3:03 pm
400y wrote:Cargo - what gearing do you run at Armoy on the 400?
Good question. I've only done it once and I don't think I have a note of it in my book
Prob something tall ish Tandragee gearing might be a decent starting point.
