Page 1 of 2
lightweight sprockets for H1?
Posted: Tue Jan 25, 2011 2:53 am
by motoxxx
Ive been having a look around trying to find some nice lightweight alloy sprockets for my H1.
I see that Renthal do some nice trick ones with big holes but only for the L model.
Does anyone know what brands make ally ones for the 89 H1 model?
i run a 14 front and a 47 rear for our local track
thannks guys
Re: lightweight sprockets for H1?
Posted: Tue Jan 25, 2011 4:07 am
no difference between H and L model sprockets
Posted: Tue Jan 25, 2011 8:16 am
by Mori Man
Sunstar make Duraluminum ones , 1/3rd weight of standard and twice as strong - got one on my bike
I've a box of Kwak kit ones - need to weigh them against the OEM and the AFAM I have - Oh, thats another maker too.
MM!
Posted: Tue Jan 25, 2011 8:42 am
by cdstirland81
don't want to cause an augument cargo, fronts are the same, H1 rears are different.
renthal do a selection of rear ones, think i got mine from B&C express
Posted: Tue Jan 25, 2011 8:44 am
If your a proper racer you'll want cheap and light...................Talon would cover than
And if you can find H or L model ZXR400 ones listed you be pleased to know that in the normal race size of 520 2004 ZX 600 rear sprockets will fit too.
As most sprocket makers use part numbers to identify sprockets that should give you two or perhaps 3 numbers to cross reference with other Kawasaki models
I've used Renthal, Talon and Afam I'd say Afam was the best of those three but also expensive N never bought Afam they came with the bike
Never heard of Sunstar..........................prob cheap Japanese rubbish
Posted: Tue Jan 25, 2011 8:48 am
cdstirland81 wrote:don't want to cause an augument cargo, fronts are the same, H1 rears are different.
There you go I'm wrong....................... what a :wanker
Whats the difference then ?
H2 the same ?
Posted: Tue Jan 25, 2011 9:06 am
by cdstirland81
H1 are deffo different, sprocket carrier, wheel, spindle etc on H1are different from the others. dunno about H2, never ordered any!
i just didn't want the guy to order the wrong ones... i nearly did!
i didn't order from B&C, it was here:
viewtopic.php?f=1&t=11567
Posted: Tue Jan 25, 2011 9:15 am
by Mori Man
I'll just douse the fire with some petrol
H1 , H2 and L hubs all vary in size/dimensions
L sprockets have a smaller internal diameter than H2 and H1
All have a 6 bolt mounting pattern and according to that cheap Sunstar mob there sprockets fit all bikes from 90 to 99 (BTW Sunstar make the OEM discs on nealry all Japanese bikes and have done since the year dot, I also think they make the OEM sprockets too and just recently new Kawasaki show the Sunstar mark on their petal discs like my ZX636 fr. wheel) But 89 have their own code
http://www.sunstar-kc.jp/cgi-local/module/sea.cgi
You can do a 525 conversion using a ZX636 sprocket with a ZRX front.
Posted: Tue Jan 25, 2011 9:19 am
by cdstirland81
Posted: Tue Jan 25, 2011 9:35 am
by Mori Man
The code for the 89 rear sprocket is
RH-103
after some searching this also seems to fit ,
[HONDA] NSR250R (MC28)(94-99) 〠NSR250R SE(MC28)(93-99) 〠NSR250R SP(MC28)(93-99) [YAMAHA] TDR250(88) 〠TZR250(86,88-94) 〠RZ250R(84,86-89) 〠SRX400(85-86) 〠XJ400L(教習用)(93) 〠XJ400S/ディãƒãƒ¼ã‚¸ãƒ§ãƒ³(92) 〠XJR400/S(93-96) 〠XJR400R(00-07,95-99) 〠XJR400RII(96) KAWASAKI ï¼ ZEPHYR750 /RS 01-03
1990 to 99 bikes are RK-110
KAWASAKI ï¼ ZX-9R 94-97 ZX-10R 06-07
Posted: Tue Jan 25, 2011 3:00 pm
by zxr500man
has any one here ever used a jt chain and sprockets?
if so would they be recomended?
Posted: Tue Jan 25, 2011 9:18 pm
by noelb
As far as I can remember, the H1 model ones are the same pattern as a lot of GSXR 750s - I can't remember what year though. I've managed to get them from race support trucks so they are definitely ones that are commonly available. I also got one of B&C but had to call them to get the H1 version. Give 'em a call.
Noel B,
Posted: Wed Jan 26, 2011 9:28 am
by motoxxx
thanks a lot cdstirland81
I had a look at the intobikes.co.uk site and they had pretty reasonable prices. ive ordered some sprockets from there.
Hopefully they dont charge me too much to ship to nz! its always the killer getting stuff all the way down here
Posted: Wed Jan 26, 2011 9:31 am
by Mori Man
motoxxx wrote:thanks a lot cdstirland81
Not from across the pond it aint
Posted: Wed Jan 26, 2011 6:29 pm
by motoxxx
yea but i cant read japanese websites to order stuff from there.
unless you know of any good ones....
