I have got a standard (reputably an L) engine, to which I want to put my flowed head with SP cams.
I am hoping the head will fit straight on, as i am not removing the base gaskit at the moment.
On lifting the standard head, I was suprised that the pistons are different to what I have seen before.
My previous engine, and all those I have seen before have the pistons like the one on the left with the 4 valve hollows, whereas the pistons fitted has a rectangle crown.
Can anyone advise as to whether the SP cams will fit ok with these and what spec they are.
Cheers in advance
Fitting SP cams and std pistons
wes
- My Bike: ZXR 400
Re: Fitting SP cams and std pistons
they are the feared flat-top low(er) compression import pistons found in some mid L's (L3-L5 ?)
they'll work .. but you want the other ones in there really.
