Fitted 636 rear shock
Posted: Fri May 07, 2010 10:01 am
by saltire88
Re: Fitted 636 rear shock
Posted: Fri May 07, 2010 10:19 am
by Deswilkie
Nice; good photo's too cheers for posting that.
Did you have to manufacture anything yourself or did it pretty much fit right on?
The original "L" one I was running was knackered (no damping at all so interesting changing from 6th to 2nd for a hairpin with the back end bouncing about). Changed to an "H" model with an SP spring but this shock seems to be popular on eBay.
Posted: Fri May 07, 2010 10:52 am
by saltire88
Had to buy the top mount, A guy here in Belfast makes them and sells them on Ebay. You have to file out a part of the swing arm (takes about an hour). You also have to drill out the eyes on the shock to 12mm as the 636 ones are only 10mm.
Posted: Fri May 07, 2010 4:07 pm
by AFM327
Looks like a huge change in ride height/swingarm angle, between the shock and top mount I'd guess over 30mm. Did you measure it before and after to know what your geometry changes would be after the new shock install? Filing the swingarm to fit, I think there's a clue there? Looks like a lot of work for a crap stock kawi shock. I'd rather spend my pennies on a ohlins/penske/matris etc...
Posted: Fri May 07, 2010 11:07 pm
by saltire88
Shock is being reworked by KTech. Total cost will be about 350 quid. Ohlins don't make a new one. New Maxton is 650. Problem I have at the minute is getting the bike to turn and it is losing me about 2 to 3 secs a lap. Spening 350 on the engine would never get me 1 second a lap. Front forks are next upgrade probably cartridge kit.
Posted: Sat May 08, 2010 6:06 am
by mick41zxr
AFM327 is on the money, 30mm in the shock will translate out to approx 60mm change in ride height. ZXR's run a short trail to start with.
Did you measure the bike to start with. Ohlins from ZX6 - ZX9 & GSXR's can be made to fit, remember they have an adjuster on the bottom
of the shock shaft for length adjustment.
Regards,
MB
Posted: Sat May 08, 2010 9:25 am
by saltire88
I didn't measure it as I know other guys that have the same conversion on their bike. I can ofcoarse still measure it to see the difference just out of interest. I had a similar upgrade on the Honda as it had an SV rear shock. It was best handling bike I ever had.
Posted: Wed May 12, 2010 4:09 pm
by AFM327
Apples and oranges, what is the stock geometry on the Honda, a quick search but didn't find it, I did find a mention that it was less aggressive than the Kawi which already has a steep front end with little trail. I've also had handling issues with the rear of the bike giving a pumping feel in fast corners with too much swingarm angle. Also when you swapped the shock did you change the spring to match your weight? I'd bet with the zxr linkage with the stock 6r spring is way too stiff.
Posted: Wed May 12, 2010 5:51 pm
by saltire88
The Shock has been sent to K Tech to be resprung to my weight and serviced. Just have to wait and see what ahppens when i get it back.
Posted: Wed May 19, 2010 9:26 am
by saltire88
Out of interest is there any suggestion for a different linkage.
Posted: Wed May 19, 2010 10:00 am
by saltire88
Ok just heard back from KTech and they can't re-gas the shock so it is not worth me re-springing it. What other rear shocks can be fitted.
Posted: Thu May 20, 2010 9:13 pm
by mark400
GSXR K6 - K7 , I have done one.
Posted: Thu May 20, 2010 10:32 pm
by kurty_22
ive a k3 gsxr one on a zxr i just bought looks totaly standard with no work done 2 it as far as i no! if ya want il pull it out and you can feel free 2 try it
Posted: Thu May 20, 2010 11:47 pm
by saltire88
Cheers I will give you a call over the weekend.
Posted: Sat May 29, 2010 8:07 pm
by saltire88
Decided to splash out. I am getting an Ohlins built for me by Graham Irvine.
