another f*ckin problem!!!
lewisdale
- CBT slow
- My Bike: zxr400 H2
my bikes doin my head in lol,everytime i fix somethin another problem arises, anyway after fitting my new reg/rectifier i took the bike out, started fine after 3 weeks of not being started,as soon as the enghine warmed up it was spluttery up to around 6k, after 6k was fine, however when i turned the bike off and tried to restart it would only run if the held the throttle flat out, and was only ticking over!!!! had a look at my inline fuel filter and could see there was no fuel pumping through, checked pipes wernt blocked,fuel tap etc all were fine, when the engine cooled down it started fine, was a bit boggy though when accelerating, and if i sit at traffic lights i have to keep it reving at 3k or itll cut out,any ideas please?
Re: another f*ckin problem!!!
carb icing maybe comes to mind, could be some more crap in the fuel but with the filter that should stop it. Are you still using the tank that was on there that i cleaned out? Might have some more water build up.
lewisdale
- CBT slow
hello mate, personally i think maybe its the pump or relay for the pump, as i took the pipe off at the tank, and when turning the engine over it wasnt pumping, its just weird how it does it when its hot, can the pumps or relays overheat and cut out?
ZXR4DAD
- My Bike: ZXR400 L5
The fuel pump can cause an intermittent problem.
Check the fuel pump contacts.
It'll probably be a Mitsubishi electro-mechanical fuel pump unit (3 diamond symbol on the back of the black cover).
undo the black screw that holds the black plastic cover, allow the wires to move in whilst gently pulling partially off; do NOT pull hard or you may damage the wire connections.
At the back end you will see a pair of contacts; check the condition of these, they may be pitted or partially burnt away.
If there is still a decent amount of metal pad on each side it is possible to dress up and square up the faces to each other using a flat nail file. But check condition after approx every 500 miles.
If the contacts are shot like the ones in the picture then a new pump is needed or pick one up at a breakers but check the contacts before you buy. Or get one (2nd hand - £25) from AMS Motor Sport (ZXR400 Specialists).
lewisdale
- CBT slow
HI, stripped the pump,cleaned the contacts and put 12v to it, its buzzing but the plunger thing in the middle wont go up n down, it does work when i move it up and down by hand so i guess the pumps buggered? are all the pumps the same or do i need to get a pump for a h2?
lewisdale
- CBT slow
hi right changed the pump and it did help a little bit!! got a decent det of carbs on there way now coz the jets were all chewed up and shitty, but i was talking to the bloke in the local bike shop and he reckons this problem sounds like valve timing? what do you think?
lewisdale
- CBT slow
and if so how easy is it to do a quick check?
- diesel
- My Bike: Zx7r
valve timing is quick and easy(ish). gotaa remove lower rhs cam chain cover and rocker cover and check the manual to make sure all markings line up etc etc. its simple enough if u follow the manual.
lewisdale
- CBT slow
ok mate will do, when i tske the cam chain cover off is it going to piss out oil?
stug
- My Bike: Yamaha R1
only a little bit tho, you wont need to drain the oil to look at it.
stug
What about the side cover?RedexRobB wrote:only a little bit tho, you wont need to drain the oil to look at it.
Hes going to check the timing, he will need to remove that cover as well.
- U_h0rnet5
- My Bike: ZXR400
Hello mate have you checked the spark plugs at all???? Mine was doing that sort of same thing a while back.
i meant only a little bit of oil will come out, you wont need to drain the oil out to look at it.
- diesel
- My Bike: Zx7r
redexrob is right. only a small dribble will come out. its not the main cover with the viewing glass on it.
