Page 1 of 2
wont fire up
Posted: Sun Mar 09, 2008 9:59 pm
by WelshD1K
Help im new bought the bike today a g reg h2 i beleive.
got slight problem got a rebuilt engine in it and it just wont fire.
turns over and over and over spits random flames back through carbs and big bangs throught the exhaust .
checked and tested:
fuel pump is pumping fuel
spark on every cylinder
fuel at all 4 carbs
seems to be loads of compression.
so been fiddlign all day today
ended up taking carbs off (bike has been stoond over a year )
lots of brown sediment in the carb bowlsso cleand it all out(as much as i could) and slaped em back on and still just
t
t bang ...
result one unhappy 18 year old lol
any ideas?? thing to check ?
im away as of 3 am tonight till friday as i work away in the week.
all advice welcome
also i need 2 bits
a bracket that the seat sits on and one of the screwy thing that holds teh carb to the manifold
p.s how the hell are you supose to take the carbs of with out droping the engine ? i found it quite hard
Re: wont fire up
Posted: Sun Mar 09, 2008 10:08 pm
by jake
carbs come off fairly easy mate. just undo the screw fasteners on the carb inlet rubbers, then they should just ease out with a bit of wigglin.
First off, make sure the ht leads are goin to the right plugs. drain them float bowls out and yr tank if the petrol is a couple of months old (mine wont fire up with the toad left in the tank from last season).
then im guessing, the carbs just need a really thorough clean, float bowls maybe stickin?
Re: wont fire up
Posted: Sun Mar 09, 2008 10:15 pm
by WelshD1K
i mean the clamps that hold then the screws are so awkward to get at.
she's got fresh juice in her today.
flats seem to be ok .
im going to buy some proper carb cleaner and do a proper job next weekend
and ht leads
left pack cylinder 2&3
right pack 1&4 correct ?
Re: wont fire up
Posted: Sun Mar 09, 2008 10:32 pm
You set up sounds about right, heres mine if you wanna double check.
http://w2.bikepics.com/pics/2007/03/03/ ... 34-800.jpg
Hows the battery? If its been stood a while it might be shot, try jumping off a car battery give some extra juice. Might wanna try some proper carb cleaner to get the carbs properly clean too.
If you get it running, bung a shot of redex in the tank and run that hrough, that should get your carbs properly sorted then!
Re: wont fire up
Posted: Sun Mar 09, 2008 10:52 pm
by WelshD1K
used a car jumper pack thing and had it turnign over for a good 20 mins in total but nout
Re: wont fire up
Posted: Sun Mar 09, 2008 11:00 pm
recently rebuilt? have you checked all the timing marks line up??
Re: wont fire up
Posted: Sun Mar 09, 2008 11:18 pm
by WelshD1K
masterofinsanity wrote:recently rebuilt? have you checked all the timing marks line up??
how would i do that ?
engien was rebuilt by a shop for previous owner
and carbs and ht leads (restrictors off to see if they where causing the aggro
Re: wont fire up
Posted: Sun Mar 09, 2008 11:21 pm
the only way you will do it is remove the ignition cover and cam cover and check by the manual that all marks line up as they should, check with the previous owner if it ran after the shop set it up.!
Re: wont fire up
Posted: Sun Mar 09, 2008 11:23 pm
by WelshD1K
he said it ran for 30-40 seconds but didnt soudn liek it was firing correct . then he bought a r6 because hsi gran died and left him money
Re: wont fire up
Posted: Mon Mar 10, 2008 4:04 am
Can't be certain but those HT leads don't look right to me
Wrong way round..................... I think
Re: wont fire up
Posted: Mon Mar 10, 2008 8:58 am
same as robs setup so they must both have them the wrong way round then
Re: wont fire up
Posted: Mon Mar 10, 2008 11:44 am
Just been for a quick look and the picture above so far as I can tell is correct
Re: wont fire up
Posted: Mon Mar 10, 2008 5:55 pm
by crushedlizard
WelshD1K wrote:seems to be loads of compression...
How much compression? I had a similar problem with my old RS125 - it wouldn't start, it's just crank over and over, occasionally
ing or popping through the exhaust. - the compression was low but apparently within operating limits. After trying everything I could, I took the barrel off and found the piston was slightly cracked. After replacing the piston/rings/gaskets, it fired up first time.
I'm not saying this is what's wrong with your bike. But sometimes you miss something and don't think to go back and check it. I mean if you have Fuel - Spark - Compression, then surely it should start? The only other thing I can think of is timing?
Have the carbs been played with?
Re: wont fire up
Posted: Mon Mar 10, 2008 7:41 pm
by Northern ANdy
cam timing is worth checking out
Re: wont fire up
Posted: Mon Mar 10, 2008 8:56 pm
by WeshD1k
how would i go about that ?
gonna grab new plugs tomorrow (work canced due to weather)
