k reg zxr400 wont start backfires
Posted: Mon Mar 29, 2010 2:22 pm
by amypauljack
hi just got a non running zxr400 on a k reg was told it ran a bit rough up until ahole in exhaust was patched up. when i turn engine over it just backfires now and again, i have added fresh fuel and there is good spark at the plugs, fuel pump works ok wot could it be the carbs i was thinking or could it be the cdi thanks paul
Re: k reg zxr400 wont start backfires
Posted: Mon Mar 29, 2010 3:56 pm
by CaNsA
drain the carbs, wait 5mins, give it a 1/3rd choke no throttle hit the starter.
let me know
Posted: Mon Mar 29, 2010 4:27 pm
by liam7200
sounds like you have had this problem b4 cansa lol
Posted: Mon Mar 29, 2010 5:36 pm
by CaNsA
before i got the lump tuned and sorted a few niggles out i did :D
Also, turn the lights off if you can.
Gives the starter motor a bit more punch.
Posted: Mon Mar 29, 2010 7:35 pm
may also be fouled plugs, so may be worth whipping them out and giving them a clean and resetting the gaps :)
Posted: Tue Mar 30, 2010 1:04 pm
by amypauljack
drained the carbs cleaned plugs still no luck just backfiring and the odd flame from exhaust and carbs
Posted: Tue Mar 30, 2010 1:23 pm
In that case get those plugs out and clean them up. They are more then likely soaked in fuel now, so a good clean and heating with a blow torch or the hob if you have a gas one.
Posted: Tue Mar 30, 2010 3:20 pm
by CaNsA
Where are you amypauljack?
Also, might be worth askin if you can have a decent forum name, cos lets face it, thats a bit of a mission to type.
Posted: Tue Mar 30, 2010 5:04 pm
just re-read your post, you already cleaned them......
how did you do it?
Posted: Wed Mar 31, 2010 11:39 am
by amypauljack
cleaned plugs with wire brush /emery cloth sparks good now, i was thinking could head gasket have gone and engine be losing compression has anyone had this happen or could ignition timing of moved somehow i am in lancaster thanks
