Oil cooler blanks
Posted: Tue Apr 21, 2015 6:33 pm
by wilko
Hi everyone just a quick one to see if anyone has had this problem. I have just removed the oil cooler an fitted blanks in its place. Fitted new filter and topped back up with oil. Fired her up and the oil light stays on. I have checked for air locks and still the lights on. Anyone have any ideas ?
Thanks in advance
Re: Oil cooler blanks
Posted: Tue Apr 21, 2015 8:51 pm
by Miles
Silly question but did you put the correct amount of oil in? The bike requires slightly more if you change the filter
Posted: Tue Apr 21, 2015 9:16 pm
by wilko
Yeh I have filled it up and it looks ok in the little window. It's got me thinking lol
Posted: Tue Apr 21, 2015 10:16 pm
by Miles
Removing the oil cooler will of course change the amount needed and I image it would affect the oil pressure. Could be what's throwing the sensor.
Having never removed the cooler I couldn't say for sure
Check with the 'racing department''
Posted: Wed Apr 22, 2015 12:04 pm
by banner001
i never had a problem with my oil pressure light when i removed my oil cooler, and i fitted blanks as well.
try adding more oil - try going halfway between the two lines when the bike has been stood for a few hours and is upright and not at an angle, if it still comes on try topping up so you are at the top of the top line, if it still comes on you might have a blockage thats restricting oil going to the pressure sensor.
i cant remember the oil-way diagram from memory, but if you print it out and "blank" off the oil cooler see where the oil should be going, and see where the pressure switch is in the system, cant remember from memory.
Posted: Wed Apr 22, 2015 8:51 pm
by wilko
Cheers banner I will have a look at the diagram and try topping up the oil. I will let you know how I get on
