Can you be restricted on top speed but not acceleration????
Posted: Tue May 15, 2007 8:51 pm
by Head-Down
im not sure if my bike restricted. the bike still gets about 55mph in first and about 85mph in second. the accelerations not to bad but once the bike gets to abou 110mph it creeps up realy slowly, could someone help! is it possible to restrict top speed but not acceleration. any help would be great.
Posted: Tue May 15, 2007 9:02 pm
by deviant
import bikes are restricted in the speedo to about 110. you can buy a little box of tricks that plugs into the back of the speedo.
do a search on the forum for "restrictor" or similar and you should find a load of info.
Posted: Wed May 16, 2007 4:16 pm
by Xphyral
Are you taking it to 13k rpm through each gear? cuz unless your above 8/9k rpm for top you'll find it will pull slowly above 110.
Posted: Wed May 16, 2007 4:23 pm
With the import restriction, yes you can be restricted on speed but not acceleration. Itll take you upto the restricted speed at the usuall rate but soon as you hit 110ph thats it it wont take you any further.
Posted: Wed May 30, 2007 11:34 am
by stuw00d
Would this restriction be in the speedo?
The reason I ask, is that I have a speedo convertor to convert KPH to MPH so that I can get rid of that useless sticker, will this enable it to get to it's normal top speed?
On a track, of course
Posted: Wed May 30, 2007 11:51 am
Yeah that would work fine mate, only thing is it mucks up your mileage readings. But yeah it would work as the speedo will never actually get to 180kmh cos itll vbe reading it in mph
Posted: Wed May 30, 2007 12:06 pm
by rene
do you mean 33bhp restricted? if its the standard import limiter then it will only restricted top speed
If its 33bhp then it will effect both
