bike dead
Posted: Mon Jul 20, 2009 7:41 pm
by Chris1984
Washed my bike yesterday not with pressure washer,but with hose,now my bike is completely dead.no lights on dash ad doesn't turn over.
Re: bike dead
Posted: Mon Jul 20, 2009 9:15 pm
Check the main 30amp fuse down on the left hand side of the sub frame, should be in a little holder of its own. If that blown then water has more than likely got somewhere it shouldnt, also check the fuses in the fusebox under the seat. :)
Re: bike dead
Posted: Tue Jul 21, 2009 9:58 am
by Chris1984
Thanks, all the fuses in fuse box are fine but the 30amp i'm having problems checking.i can't get into it to check its corroded shut,i guess this is the problem.
Re: bike dead
Posted: Tue Jul 21, 2009 10:31 am
by Chris1984
I also had an alarm fitted saturday,i'm wondering has this drained the battery,its brand new battery but have a feeling its not charging properly so might need new rec.How do i check battery?
Re: bike dead
Posted: Tue Jul 21, 2009 10:38 am
Ahh if its corroded that could be your problem, try and prise it apart. Best way to check battery is with a multimeter. Its not uncommon for alarms to drain the battery, better off without them to be honest. Measure the battery voltage if you can and let us know what is says. Alternatively charge the battery and see if it changes anything. :)
Re: bike dead
Posted: Tue Jul 21, 2009 10:54 am
by Chris1984
don't mean to sound thick never used one before but how to i use the multimeter?Don't laugh i'm a newbe to all this :please
Re: bike dead
Posted: Tue Jul 21, 2009 1:02 pm
by Chris1984
worked out multimeter i think,battery is reading 12.19 if that makes sense
Re: bike dead
Posted: Tue Jul 21, 2009 1:16 pm
by Chris1984
RedexRobB wrote:Ahh if its corroded that could be your problem, try and prise it apart. Best way to check battery is with a multimeter. Its not uncommon for alarms to drain the battery, better off without them to be honest. Measure the battery voltage if you can and let us know what is says. Alternatively charge the battery and see if it changes anything. :)
Thanks rob think i've found my problem i managed to get into 30amp fuse and its melted also its only a 25amp thats in there.could this be the reason my headlight bulbs keep blowing
Re: bike dead
Posted: Tue Jul 21, 2009 5:18 pm
by Chris1984
Bike is now alive again,you get a good buzz when you fix something when you thought you couldn't.thanks rob for pointing me in the right direction.ripped my thumb open trying to prize it open but atleast the bike is running again :excited
Re: bike dead
Posted: Tue Jul 21, 2009 9:42 pm
Glad to see you did it, well done for doing it yaself too!! Yes, always a buzz when a bike works when you fix it, just as good as riding the bike itself!! :smt003
