Page 1 of 2
Fan not working..
Posted: Mon Jul 20, 2009 2:29 pm
by Jeppo
After replacing a fork seal and rebuilding the front end my fan just won't work anymore :smt017
I've connected everything the same as when i took it apart, and have checked again today but just can't get it to come on.
It isn't seized as it spins freely by hand.
What should i be checking, and how would I short circuit it to make sure the fan itself is working...
Re: Fan not working..
Posted: Mon Jul 20, 2009 2:44 pm
by CaNsA
You prolly already know this but the fan only comes on when the lump gets a bit too toasty.
There is a fuse under the seat for the fan. Check that.
To check the fan, pull the 2 wires that go into the front of the rad and short them. The fan should come on.
If checking all that the fan still doesnt spin then the sensor on the rad (where the 2 wires goto) might be shot.
Posted: Mon Jul 20, 2009 2:49 pm
if you bridge the 2 wires off the rad sensor the fan should spin, if it don't the fan is shot, if it spins then the sensor is shot.
don't try and spin the fan with it connected up, if i remember right the fan is live all the time and if there is a short and it fires up guesss what's gonna happen to your fingers??
Posted: Mon Jul 20, 2009 3:02 pm
by CaNsA
Whose hand is that?
Posted: Mon Jul 20, 2009 3:17 pm
dunno mate found it on google but this happened to my neighbour
Posted: Mon Jul 20, 2009 3:29 pm
by Jeppo
Duly noted lol.
I tried shorting the two wires on the sensor thing (the bit that sticks out about half way up the right hand side (as you look at the bike)) and nothing, so i'll check the fuses, if no luck then fan replacement?
Posted: Mon Jul 20, 2009 3:32 pm
by CaNsA
Just checking,
you did short the wires and not the pins sticking out of the fan right?
And FYI, i got a price from Cradley for a new fan and they said £230ish i think, i said ill get back to them lol. Turns out it was just my sensor.
Posted: Mon Jul 20, 2009 3:53 pm
by Jeppo
Err i shorted the wires that stick out of the sensor thingy that sticks out of the radiator.....
Posted: Mon Jul 20, 2009 4:23 pm
that wont do anything mate you need to bridge the wires you take off that.
Posted: Mon Jul 20, 2009 4:56 pm
by Jeppo
Sorry i'm confused now. I pulled the two wires off the sensor thing and touched the ends together, is that not right?
Posted: Mon Jul 20, 2009 6:53 pm
Jeppo wrote:Sorry i'm confused now. I pulled the two wires off the sensor thing and touched the ends together, is that not right?
Yeah thats what you should be doing.
Posted: Mon Jul 20, 2009 7:18 pm
by Jeppo
Ok cheers, well that did nothing, so i must have broken the fan when i dissassembled the front end, bummer. Anyone got one going spare? lol
Posted: Mon Jul 20, 2009 9:21 pm
have you checked the fuse aswell?
try out resident breaker 'falloffslowly' for spares, hes bound to have one. :smt003
Posted: Tue Jul 21, 2009 10:02 am
by Jeppo
Checked the fuse and it had blown, replaced it and still touching the wires together has no effect, though i tried it with ignition off but i thought it should work this way?
Posted: Tue Jul 21, 2009 10:12 am
yeah it should work with ignition off too, did you check the fuse again after re-trying? Hopefully its not blown again. If it has you'll need to get to the fan wiring and measure the resistance across the fan motor, if its 0 ohms then the motor has shorted internally. If not then your problem is elsewhere.
