Hi Chaps,
Need HELP with my zxr 400 L1...Bike was over charging the battery witch led to the bike not starting unless I jump started it. It then ran fine on a run, when I tried to start it again I needed to jump start it again. Seems as if the battery goes flat after about 2 mins. I have replace the rec/reg there is now no charge going into the battery at all... the head lights dont come on at all now either. Any ideas?
no head lights, not starting & battery not charging... HELP
littlemike
- My Bike: zxr 400l
Re: no head lights, not starting & battery not charging... HELP
sounds like the stator coil is faulty, you can check the 3 wires coming from it with a multimeter,look in the manual for details, think you are looking for 43v across the wires.
littlemike
- My Bike: zxr 400l
masterofinsanity wrote:sounds like the stator coil is faulty, you can check the 3 wires coming from it with a multimeter,look in the manual for details, think you are looking for 43v across the wires.
hi thanks for that,
I have tried that & sometimes I am getting a reading of between 42-45 volts other times I get nothing? Any more ideas?
I bought a new battery 6 weeks ago & it is now compleately knackered. Someone has spured a lead off the alternater to the fuse box..for some reason... Please help..
Littlemike
