weak indicator flash
Posted: Sun May 27, 2007 6:44 pm
by Bestie
hi all,
ive had a full set of hein gericke mini arrow clear led indys on my bike for a while, and while i seem to hav sorted the problem of the leds blowing (rain gets in so be sure to sillycunt it before installation, only on the rear though so thank the sweet baby jesus for the undertray!!)
basically, they blink very very very weak, infact so weak you cant see them from a foot away, this is just when the ignition is on.
fire up the baby, and rev the throttle, and they increase in power the more you rev. after a few miles, idle at lights, they are ok....
now, cold or hot, run or not, when i arm or disarm the alarm, they are brighter than a pothead with a great idea!
so, can anyone help me to rectify this little saga, as im getting a new set from gerickes, all metal black, with little amber lights on the back...cool....then i can fit the undertray and led rear lights and off i go!
andy
Posted: Sun May 27, 2007 10:16 pm
by Dubstar
you got the relay needed for when fitting led indicators ? also your battery ok ?
Posted: Mon May 28, 2007 6:38 am
not had any experience with LED indys but i have seen in all the shops there's a special little box which you need for LED indys which must be the relay Dubstar mentioned.
Posted: Mon May 28, 2007 10:18 am
by Bestie
hi there
aye, got a relay for each indy and its wired correctly, they dont blink fast, which is a common prob if you dont have the relay.
battery fine, been on optimate whole time i was in oz, as mentioned they are vbright as feck when arm disarm the alarm!
weird non!
Posted: Mon May 28, 2007 2:38 pm
by SplaTZXR400
first thing i'd check mate is connections. iv had probelms with every indi after a while, contacts corrode from rain, also i live next to the sea which dont help. get a multimeter on it and check for a good continuation. if u say its fine with alarm, do u mena with engine and electrics off? in which case check alternator or aything that could divert power away from the indis.
Posted: Mon May 28, 2007 2:47 pm
by Mori Man
Go round your bike and wire wool all your earth connections, also sounds like your alarm might be sucking the juice out of your battery too so go round all it's connectors and clean them up and fix them securely.
Hopefully you'll get a bright result from that :smt001
Posted: Mon May 28, 2007 5:40 pm
by Bestie
spla - yeah, its with the engine and electrics off....
will try the wire wool thing, though im pretty sure none of em are corroded, the indy ones on the front arent as i fit them myself and checked them last night whilst inserting new blue iridium bulbs, they are cocooned in leccy tape and still as clean as a preachers bed sheets!
still ill try charging the batt and cleaning contacts hopefully it will help
ta
ill post any details if it doesnt sort em out
