				electrical - side stand switch maybe?
				Posted: Sun Mar 18, 2007 2:39 pm
				by pete
				hi all. when i turn the ignition on sometimes the neutral light doesnt come on even when the bike is in neutral. when i pull the clutch in the engine then turns over and the light comes on. any ideas? im thinking the side stand switch covered in crap/corrosion? thanks all. pete
				Posted: Sun Mar 18, 2007 6:28 pm
				hello mate, could be covered in crap, also, check the bright green wire that goes behind the sprocket cover, it pushes onto a contact and could be covered also causing it to play about with the neutral light.
So give both a clean and see how it goes
				Posted: Sun Mar 18, 2007 7:17 pm
				by pete
				thanks RobB. yeh crawled out of bed and had a go. cant do much atm with a bad back but seems to have sorted the problem for now...... time will tell.
				Posted: Mon Mar 19, 2007 8:14 am
				by Northern ANdy
				which years of bike have a sidestand switch please?
				Posted: Mon Mar 19, 2007 8:44 am
				as far as i'm aware they all have one.
				Posted: Mon Mar 19, 2007 10:51 am
				by diesel
				o got an H1 and mine has one
				Posted: Mon Mar 19, 2007 4:36 pm
				by Northern ANdy
				mine hasnt got one lol? will have to investigate that
				Posted: Mon Mar 19, 2007 5:05 pm
				If you take em off you can still get the bike to work, i think you just have to join the wires together.
				Posted: Mon Mar 19, 2007 6:15 pm
				by deviant
				think all kwaks have them - the gpz does, i've heard of them on a zephyr 750, fairly sure the zzr11 I stripped did.
