Starter button no start, not even a click!
Posted: Mon Jan 18, 2016 4:12 pm
Hello all!
My bike doesn't want to start from the button. I can't even bump it. Even when i press the starter you don't hear the relay click. Dont worry, the killswitch isn't on and sidestand isn't down
If i bypass the relay the bike starts fine no problem, so there's no actual issue with the charging/firing electrical side of things. I also tested the relay and works as it should, does click when power supplied to it and the fuse is fine.
Which leaves me to think its either the starter button or killswitch causing the problem. I looked in the manual but can't seem to find a check of any sorts, how would i go about fault finding these components?
The other thing is I have a giraffe datatool veto evo alarm immobilizer system, so have no idea if this is the issue. It shouldnt be as it bleeps to say the alarm is disabled and i did re-set it just incase. (all other functions work like service mode, adjusting sensitivity of nudge etc)
Thanks!
Thanks!
