LED indicator problem
Posted: Sat Sep 24, 2011 7:16 am
by tink
this is confussing me why
fitted front and rear led indicators and also led flasher relay
first problem i had was when i indicated right all four flashed and the same when i indicated left, after removing the bulb on the indicator reminder the problem was solved indicate left and left flash and same with the right.
But then i fitted a led bulb in the reminder light and its back to all four flashing.
Anyone know how to solve it?
Re: LED indicator problem
Posted: Sat Sep 24, 2011 12:40 pm
by razzcolio
should imagine its a current issue,
wrong indicator relay coz theres still too much going through the system?
or summat i duno lol
i couldnt get the front AND rear to go either, ive only got the front led, the rear is normal,it works fine...
Posted: Sat Sep 24, 2011 6:00 pm
by tink
they flash fine until i put a bulb in the reminder light
Posted: Mon Oct 24, 2011 6:45 pm
by tink
This is really getting on my nerves now tried a number of differen LED bulbs now
Posted: Thu Nov 17, 2011 10:31 am
by paula w
Check all the wires and connectors might just be wires making contact that shouldnt hence all coming on t the same time it could be shorting something out x
Posted: Sun Nov 27, 2011 7:34 am
by tink
wiring has been checked and looks fine.
Still got the problem
Posted: Thu Dec 01, 2011 9:22 am
by Mori Man
How do the LED indys earth ?
Check the connection inside them, try earthing them out yourself with additional wire and see if it cures it then make a permanent solution.
Wrong relays usually have them flashing at the wrong rate.
Posted: Thu Dec 01, 2011 7:16 pm
by tink
just brought a couple of led load resistors to fit to the rear ones to see if they help and gonna leave the front leds to run off the led relay
Posted: Fri Dec 09, 2011 9:27 pm
by tink
solved the problem by putting a 50w resistor on each of the rear led indicators.
Now have my light flashing on the indicator panel when they are on and the resistors also solved my 10%-100% flash
Posted: Tue May 15, 2012 1:46 am
by armo
Hi there I was just wondering how and where you fitted the resistors for the indicators as I am having the same problem with mine
Posted: Sat May 19, 2012 5:38 am
by tink
armo wrote:Hi there I was just wondering how and where you fitted the resistors for the indicators as I am having the same problem with mine
I fitted 1 to each rear led indicator and changed the relay to a led one
Posted: Sun May 20, 2012 7:51 am
by armo
Yes that what I tryed to do and some reason I seem to have all 4 on at once still it's really confusing me now, but if I put a extra bulb set of indicators on the front it works fine, it's frying my brain at the minute haha
Posted: Sun May 20, 2012 10:15 am
by CaNsA
tink wrote:solved the problem by putting a 50w resistor on each of the rear led indicators.
Posted: Sun May 20, 2012 7:24 pm
by armo
I am gonna sound like a idiot now but I did all that but still doesn't seem to of worked, wondering if any body had any ideas
