plug caps with ignition coils
Posted: Sat Oct 31, 2009 4:34 pm
by vince67
Hello mates
Anybody has tested to put on zxr400 plug caps with ignition coils like these:
I think use ignition coil plug cap from ZX6r models,
any feedback about this ignition modification?
thanks
Vince
Re: plug caps with ignition coils
Posted: Sun Nov 01, 2009 1:01 pm
yes, i think it was one of our users 'mongo', who had a working set up with tstick coils
quick search and here we are
viewtopic.php?f=1&t=7367&hilit=stick+cil+stick+coil
Posted: Sun Nov 01, 2009 5:58 pm
by vince67
thanks
No easy for me to find it because I didn't knew that the english name is "stick coil "
regards,
Vince
Posted: Sun Nov 01, 2009 7:15 pm
theres a couple of names for them, plug cap coil is another ive heard. Good luck with it all
Posted: Mon Nov 02, 2009 11:45 am
by zimm
use them on my H1.. came off a ZX6r-C1h
Posted: Mon Nov 02, 2009 12:33 pm
by vince67
Hi,
OK, thanks
for the connection, according important information in the other topic from the links above, could you confirm if I must connect the coils in serial to the control wires and not in parallel?
Posted: Mon Nov 02, 2009 2:20 pm
by CaNsA
to quote from mongos thread
You can not run them in parrallel, it does not work, you would need to spend some time as mentioned with resistors etc.
