FFS! pissing footpeg bolt!!
Posted: Fri Aug 20, 2010 8:20 am
by MillaMeter
Hi,
I need to change my gear shifter on my 636 Ninja, (same setup as the 400) I took the whole rearset off, went to undo the bolt on the back... and it just rounded the alan hole. :smt013 :smt013 :smt013
Any ideas on getting this sodding bolt out without damaging anything would be lovely!?
Regards
Rich
Re: FFS! pissing footpeg bolt!!
Posted: Fri Aug 20, 2010 8:29 am
Foot rest bolts are threadlocked in..............and that thread lock is factory supplied with a new bolt if you buy one.
Not easy to get it out..................before you started you should have applied heat lots of heat.....................now that it is rounded off you options are limited and will more than likely involve drilling...............
Posted: Fri Aug 20, 2010 8:35 am
by MillaMeter
cargo wrote:Foot rest bolts are threadlocked in..............and that thread lock is factory supplied with a new bolt if you buy one.
Hi,
shiiiiite.... thought as much, of well, guess my old man will be setting up the piller drill later then.
Cheers anyway cargo
Regards
Rich
Posted: Fri Aug 20, 2010 9:02 am
Yup, drilling is just about your only option had this problem myself the other Day when taking off my rear mudguard, giraffe allen bolts rounded out
Posted: Fri Aug 20, 2010 1:12 pm
by extonyg
you might be able to bang a spline/torx socket into it.
or a 'round off' socket over the top of it
Posted: Sat Aug 21, 2010 12:03 am
try the next size up allen key and blat it in with a hammer, bit of heat and bobs your uncle.......failing that cut it off with an angle grinder
Posted: Sun Aug 22, 2010 7:03 am
by rabidnz
can you dremel a nice chunky slot into it and impact driver it out after aplying liberal heat/penetr8
