USD FORK TOPS
Posted: Tue May 19, 2015 12:41 pm
by julesfay
Hi,
Can I take off the fork top while it is still on the bike without the internal springs shooting out?
I need to do a quick fix for a track day, i.e top the oil up on one of them due to leaky seal, I can get the repair done properly next week.
jules
Re: USD FORK TOPS
Posted: Tue May 19, 2015 2:44 pm
by CaNsA
Yes, when you unscrew the fork tops the fork upper should move freely.
The damper will hold everything else together.
Re: USD FORK TOPS
Posted: Tue May 19, 2015 4:53 pm
by julesfay
Cheers, I have changed normal fork seals on Ninja 600, & XJ 600, but was unsure about the USD forks as there is a spring compression removal tool required.
Jules
Re: USD FORK TOPS
Posted: Wed May 20, 2015 10:51 am
by banner001
i doubt you will pass trackday inspection if the seal is leaking badly, plus do you really want it all over your front brakes and leaking on the track?
you need the compression tool if you want to fully disassemble the forks only. you will need some way to measure the air gap/amount of oil in the top of the fork tube, and its best if the forks are vertical for that...
