				L model rear shock manual section
				Posted: Wed Mar 26, 2014 5:08 pm
				by mxs
				Is it me or the rear shock section in the L manual is missing? I will need to reset a ride height to stock (bought a bike which someone lowered).
http://www.zxrworld.co.uk/Manuals/L%20M ... r%2012.pdf
The H model has the suspension complete, but has nothing about the stock location of the top shock mount etc. Anyone knows? I can figure it out, but will not have much time, as I will be in on vacation and want to ride instead of wrenching on a bike or figuring out a setup. ...
				Re: L model rear shock manual section
				Posted: Wed Mar 26, 2014 6:48 pm
				by CaNsA
				Works for me, try >
right click, save as/save target
I have downloaded and attached it to this post.
				Posted: Thu Mar 27, 2014 2:26 am
				by mxs
				I should have been more descriptive ... I have no problem to do what you did, to download the pdf files, but if you open the chapter 12 you attached there's nothing about rear shock ...
				Posted: Thu Mar 27, 2014 2:41 am
				by CaNsA
				Ah,
Section 12-4 has the specs for it, what exactly are you after?
				Posted: Fri Mar 28, 2014 5:11 pm
				by mxs
				Stock mounting position of the rear shock (actually need it for the front forks too). In another words I want to set the bike to stock ride height. There has to be some section about rear shock mounting and removal. it does look like it's completely missing.
12-4 section has only a table with rebound and preload stock settings, nothing about settings effecting ride height though
Sure, I can ride as is and start slowly dialing it in, based on test rides, but I will not have a time to tinker around .... I hoped people here would have known, since many had their bikes apart as I can see.
				Posted: Fri Mar 28, 2014 7:16 pm
				by CaNsA
				So you want to know how high the top shock mount sits into the frame?
Set the rear shock to stock settings, as stated in the manual, then adjust the hight adjuster so that the seat is 760mm from the floor with the bike standing upright.
				Posted: Tue Apr 01, 2014 7:14 pm
				by mxs
				That would work ... where exactly do you read that?
BTW, anything on the stock position of the front forks in the triple clamps?
				Posted: Tue Apr 01, 2014 8:18 pm
				by CaNsA
				I got teh seat height info from the specs page
http://www.zxrworld.co.uk/zxr400/specs.html
AFAIK, the forks sit in the clamps as far down as possible without gripping the fork tops.
				Posted: Thu Apr 03, 2014 12:09 pm
				by mxs
				Thanks, that will do.
