My Uni-trak has no grease-gun nipples...
Posted: Mon Mar 12, 2012 8:18 pm
by banner001
...any one know where they have gone to?
I cant seem to see anything about models without grease gun points...so is this an aftermarket linkage on my bike? Its a '94 L-model.
Re: My Uni-trak has no grease-gun nipples...
Posted: Mon Mar 12, 2012 9:41 pm
Never seen a bottom linkage with grease nipples on a ZXR400
Posted: Wed Mar 14, 2012 11:47 pm
by banner001
they are shown in both manual's though...
from microfiche
http://www.zxrworld.co.uk/images/Lseries/lrearshck.gif
or is this just for early L models and not the later ones?
Posted: Thu Mar 15, 2012 3:06 am
thats a mirco fiche image not the manual.
clearly you dont have nipples on your linkage......................and it looks bog stock to me
Posted: Thu Mar 15, 2012 6:55 am
I havent got any either although i have seen them in the fiche as you mention. If you want to grease them up youll have to get it all apart, but as its all sealed its probably ok.
Posted: Thu Mar 15, 2012 10:58 pm
by banner001
just checked both manuals, they are shown on the illustrations as well as in photographs, i think it was section 12-12 for the H model, the L model has them illustrated as well...never mind, just it mentions them in the maintenance section, and getting a grease gun on them is easier than taking the rear shock linkages apart.
Posted: Mon Mar 19, 2012 10:53 am
by Tirpitz
RedexRobB wrote:If you want to grease them up youll have to get it all apart, but as its all sealed its probably ok.
Come on Rob, are you being serious? It's well known that because this job on a Jap bike with no grease nipples is a PITA it is one of the most neglected service tasks, which is why so many older Jap bikes have shagged suspension bearings. Not to mention the fact that the Kwak factory seemed to treat grease like gold.
You do need to strip the suspension down and grease it and you are likely to find that there is bugger all grease on the swingarm bearings. You may well find these bearings, or the sleeve bearing surface, are shagged.
This job definitely needs doing at the recommended intervals, especially if the bike is used in the wet.
Posted: Mon Mar 19, 2012 1:10 pm
Tirpitz wrote:RedexRobB wrote:If you want to grease them up youll have to get it all apart, but as its all sealed its probably ok.
