Re: Spongy brake lever
Posted: Mon Apr 28, 2008 6:14 pm
Ive had this problem aswell with my old brake lever. Fitted new braded hoses, changes the master cylinder springs and that bled them for ages and they seemed to be alot better but after a while they went back to being the same as they were before!
So i bought Brembo Radial master cylinder which has worked wonders as its got a bleed valve on the top of the master cylinder aswell. But i think the calipers need a little work as the seals dont look great and not all the pistons are moving freely enough! Will let you know how they are went i service them this week.
When you pull the lever does t seem to not really work and they all of a sudden there is loads of pressure???
