part not on micro
Posted: Sun Apr 20, 2014 9:33 pm
by Miles
Hey guys, rebuilding rear caliper and after pressing out the bushing that the torque arm connects to I noticed that a small metal ring sits around the bushing. Upon looking at the rear caliper diagram to order one up I've discovered its not there? Bushing part number 42036.
Perhaps it comes with the bushing but I would have thought it would be on the diagram
Re: part not on micro
Posted: Sun Apr 20, 2014 10:23 pm
by Miles
Hey Cargo, thanks but that's the diagram I was referring to. Its the bush between the two seals that has this small sleeve buts its not on the diagram
Would of helped if I'd had put a Link up in the first place
Posted: Sun Apr 20, 2014 11:50 pm
by CaNsA
Posted: Mon Apr 21, 2014 12:47 am
by Miles
Unfortunately not, I thought it would be located along with the bolt that goes through the caliper but no luck.
Very odd that its not in the diagrams
Posted: Mon Apr 21, 2014 1:46 am
by CaNsA
Posted: Mon Apr 21, 2014 11:26 am
by Miles
Yes that's the sleeve but the bushing doesn't appear in the diagram, maybe I'm just being thick. I'll just clean the old one up and reuse
Thanks guys
Posted: Tue Apr 22, 2014 12:21 pm
May come as part of the torsion bar?
Posted: Wed Apr 23, 2014 9:53 am
by banner001
a photograph of the ring and where it it supposed to seat might be a good idea about now?
Posted: Wed Apr 23, 2014 11:08 am
by Miles
Photo shall follow
Posted: Sun Sep 14, 2014 5:16 pm
by Miles
Sorry took so long, as you can see the metal ring should be in the hole that the bolt goes in, between the caliper and the bushing but I can't find it on the diagrams anywhere. Without it the bushing and bolt just rattle about.
My only thought is that maybe the steel ring and the bushing come together but the fische shows it as one
I took one out when I stripped the caliper so obv I need to put one back in
